jlamb30
- Sep 6, 2020
- 24
- 369
- 281
- Lake Park, GA
- 2020 Civic Si Sedan • 03 Kawi ZX-6R 636
Highest I've seen with mine is 19. Most of the time, the high is 16-17.
I only tried twice to get the boost all the way up. First time was 19 or 20 psi, the second time 22 psi. Don't really wanna gun it too much till I know what tune this thing has. I already ordered the ktuner from TSP, so I'll know soon enough.Are you consistently getting 22 psi?
Let us know, I read your other thread as well so I'm curious what you find out.I only tried twice to get the boost all the way up. First time was 19 or 20 psi, the second time 22 psi. Don't really wanna gun it too much till I know what tune this thing has. I already ordered the ktuner from TSP, so I'll know soon enough.
Yea no. You will never see 20-22 psi on the factory tune. You will almost always see 16-17 psi and occasionally 18.How often have you seen 22psi? Were you in sport mode?
If you were in sport mode and under the right conditions, you can see 20-22psi on the dash boost gauge. I've seen 21psi before I was tuned. Also in a 2019 Si.
In case everyone forgot, a stock Si pushes out 20.3 psi from the factory.
i'll post an update here after i've reflashed it. aside from trying to figure out the mystery tune, i've done my own multi point inspection of the car. So far i've replaced missing screws from the engine cover underneath the car, missing bolts/washers/grommets from the intake and changed the oil to pennzoil platinum + K&N filter. The damn thing had an AC Delco filter on it, with god knows what oil. Went ahead and replaced the cabin air filter too.Let us know, I read your other thread as well so I'm curious what you find out.
It's kinda disappointing that this isn't a factory tune lol. But I had a feeling it wasn't stock the first time I hit WOT in her. Coming from a 180hp 1.5t hatch, this felt like way more than the 20 extra hp/torque the Si brings. I hope the factory tune isn't too much of a let down lol.Yea no. You will never see 20-22 psi on the factory tune. You will almost always see 16-17 psi and occasionally 18.
Well, just an update... i actually managed to get in touch with the previous owner, a former member here, and it definitely still is tuned. He was running a flex fuel kit, so that explains that P0128 code that won't go away. Unfortunately he doesn't know much about it, as it was done by someone else. The rest of the car has been returned to stock. Am I running any risk by driving the car on just premium gas, on the mystery flex fuel tune?KTuner does NOT download the factory tune from the ECU on the initial flash. The Factory tunes are kept on KTuner servers and get upload to the KTuner device when you go online through the program. There are even separate factory options if you received the Oil Dilution update.
You can flash over anything that is currently on the ECU. The ECU is not locked to a specific device. The device is locked to a specific ECU.
If you have KTuner, make a conservative tune with rev hang disabled. All the basemaps are safe by the way.
If you are looking for some get up and go, for minimal $$$, pick up Phearable 1.5 tune. Stock clutch can hold this tune no problem if you know how to drive. It is absolutely amazing.
