Romeoridgee
Honda Dealer Tech.
- Rob
- Mar 7, 2019
- 36
- 1,844
- 882
- Maryland
- 19 SPT 17 EX-T 08 LX 21 CRV 12 Acc 14 328I CONV
- Vehicle Showcase
I don’t have this setup installed, but from research and mild testing I know that setup will work. I’ve already tried using RI c1 port injection kit with modifications. Used the ri rail with honda fit feed hose on spacer, plugged injector holes in head, in conjunction with type r IM and lost power with that IM. So I returned to stock rail and feed hose. Haven’t gotten to the hard pipe yet. But connector on fuel pump module is same, and placement between 2 hard pipes is similar.Wow!! Did you do this yourself? If so how did it feel?
also Do you have part numbers for the type r fuel pipe, and pressure regulator.
