ManitobaSI
- Scott
- Jun 29, 2018
- 21
- 1,277
- 2,424
- Manitoba, Canada
- 2017 Civic SI
- Vehicle Showcase
I have had the MAP oil cooler. I cannot recommend it. Their pedestal hangs on by two threads with a nut. It’s a bad design. When I went to remove it the nut was loose and I had used thread lock. The pedestal relys in this one nut vs the Siri moto which has a proper brace.If you do offer a full pan with the baffle pre-installed, please also consider offering the pan with that oil gallery you found for the potential oil pressure sensor drilled+tapped.
I just installed gauges and routed wires for oil temp and pressure sensors last month, and am just now realizing how few options exist to install an oil pressure sensor on the L15. I think @Hondanickx has been struggling with this as well.
I've not yet found any standard/universal filter sandwich plates confirmed to give enough room to fit a pressure sensor.
And even for the Sirimoto oil cooler kit with it's funky filter extension, they want you to install an extra 18" length of -3AN to dangle the pressure sensor from:
So based on my searching, I think the MAP oil cooler kit with the odd filter standoff elbow might be the only game in town that gives you a place suitable to hard mount a pressure sensor.
Had no idea the situation was so dire (for pressure sensors in specific, because of the larger sensor body) before I had the pressure gauge/sensor already installed and just sitting idle in the engine bay. But I suspect that everyone concerned about oil pressure enough to add a baffle is probably going to appreciate an additional location for an oil pressure sensor...
When I got the MAP kit I had to make my own oil lines. Theirs was too short. To make the pedestal work safely it should be machined for proper connection to oil pan.
