rednichols
- Red
- Aug 10, 2023
- 7
- 53
- 32
- Australia
- Honda CRV 1.5 VTEC Turbo 2023 L15BG FFV (Thailand)
My OBD reader having misled me on what my CRV outputs power wise (my earlier posts here), I recently had the good fortune of its maker OBDLink replacing it with a new unit, and simultaneously provide a firmware update. The clue was that the EX model was showing different hp and tq numbers on the 'gauges' (high) and on the underlying logs (lower) so I asked why.
Now they're the same: lower, to the point where these readings are now about 200hp/210tq. More reasonable in view of the pushback my 'findings' received originally that showed much higher power ratings. And these new ones are reasonably close to what the Matchbot app suggests with my settings for bsfc and v.e.
My original search was not for power ratings but to learn the boost of the particular engine I have, which is the Thailand model known as the L15BG and comes w/out a boost gauge of its own. The good news for me: the boost reading is a minimum of the 18.4 psi gage that I had expected, and recently I've had a reading of 19.3 gage which suggests that the engine is set up to match the L15BE in the Accord, which is 20.2 psi gage. The Wiki chart for the L15 engines suggest this also. No matter, time will tell:
Soon to find out what the results are with E85 given that this is Honda's FFV and the car is rated for same. The EX by OBDLink allows me to chart spark advance, too, which at boosts above 5000 rpm have changed from as much as -10.5 degs to as much as +18.5 degs at those higher revs. This is a result of my switching from 91RON that is minimum for the car here, to 98RON that is the highest octane available here.
The OBDLink is also charting the lowered intake temps I was able to achieve with the factory engine but with shields (1) between the intake crossover pipe and the hot turbine (the Honda engine was designed to run at temps up to 2000F for fuel economy and pollution reasons) and a now revised snorkel that channels cold 'ram' air from the forward lip of the bonnet. Temps are the same at the engine's sensor as ambient, which then means that air density is equal to the pressure ratio of the compressor, which means more fuel by command of the ECU, which means more power. I'm unable to chart fueling though.
As mentioned, next to see how the readings change going from 98RON to E85. Do already know that my 'mpg' will get noticeably worse.
