R00080
- Daniel
- Mar 18, 2018
- 2
- 23
- 8
- Seaside, CA
- 2017 Honda Civic Type R
I definitely should have researched more before starting. I was swapping out my rear brake pads and rotors and everything was going good. I used an Autel to get into maintenance mode and had the new rotors on but when I was trying to compress the pison on the caliper it would not budge. I started second guessing myself and knowing better decided to try putting the car back in normal mode and then back to maintenance mode. When I did that the piston drove to infinity and the car will not go back into maintenance mode. My question now is if anyone has run into this isssue. For me to swap the caliper how can I get the car back into maintenance mode? Or is that step necessary if swapping the caliper out? I did some searching but couldn't find a solid answer on that. If anyone knows I'd appreciate the advice. Thanks!
