Austin@Wunderladen Racing
- Austin
- Dec 6, 2021
- 46
- 1,132
- 2,375
- Chicago IL
- Website
- www.wunderladenracing.com
- 2018 FK7
- #211
Yes fly cutting larger valve reliefs into the pistons is something plenty of machine shops can do, but I'm trying to avoid adding in customized variables like that when the main reason for doing this is to make an easily replicable example for others to follow and show that these engines can make really solid power numbers without any crazy work. I think the JEs fit the bill and get the job done at a lower price point, I would be more inclined to go with the Wisecos if I was shooting for some seriously stupid power like 600+hp. As it stands there may not be clearance issues with the Wisecos but with the season fast approaching in April I need to pick and choose what all I'm going to check over on the engine prior to assembly and just sticking in the pistons with larger reliefs means one less thing I'd have to spend a lot of time to check otherwise.Would you be able to just cut slightly deeper reliefs in the Wisecos if that's your only gripe?
Any decent machine shop should be able to do this fairly easily, if piston to valve clearance is actually an issue with cams. If it is and machining them works, maybe wiseco would be interested in the findings and update their offerings.
Rods, pistons, cams, springs, oil pump and a bit of head work should be a recipe easily capable of 400whp with the right stock frame turbo upgrade. This isn't meant to be the ultimate build to set power records, the head gasket sealing system and cylinder would require more attention for sure if that was the goal. It might be something I consider pursuing in the future but at the moment I care more about help others achieve higher power goals and proving that the L15B has a place in the aftermarket especially as the performance variant K series become harder and more expensive to source over the coming years.
