Oh okay. Hmmm nope the car was brand new when I got it. Seems easy to replace tho.Material defect? I think that's the vacuum line that is connected to the PCV system after the series of baffles and the PCV valve, so it's kind of necessary to siphon off the evaporating fuel in your oil.
It would be a line that is removed to install like a mishimoti catch can. Did you buy the car used? Perhaps they ran a catch can before selling the car and messed up the original hose.
Honestly I have no idea. I haven’t you bed up there and i don’t think it’s touching the hood either. Going to pick up a new line from autozone and throw it on today.That should be the vacuum line for the PCV as above
https://www.hondapartsnow.com/parts-list/2018-honda-civic--2dr_si-ka_6mt/engine/pcv_tube.html?pnc=2
Any chance the hose was twisted or moved at all and is rubbing against the hood? One possible way it would tear.
Honestly, being rubber and being subjected to repeated intense heat and cold weather (especially if you drive in winter), sometimes they just tend to split. You should be able to replace it with a hose from your local auto parts store or menards/lowes/HD so long as theyre the same grade of tubing.Hmmmm. Any idea how that could have happened ? Lol
Are there any other hose to watch out for?
it seems that specific hose is very common to break because on some previous post since i joined. They also mentioned that
Hi,Material defect? I think that's the vacuum line that is connected to the PCV system after the series of baffles and the PCV valve, so it's kind of necessary to siphon off the evaporating fuel in your oil.
