Violent shaking and clank when letting on/off gas -- not cv axle?
snapshot
2020 Civic Sport Hatch
After lowering my car there has been violent shaking between 30-60mph while accelerating, going away before and after and when not accelerating. On top of this, there is a clank and what feels like a shift of weight when letting on and off the gas and breaking. Searching this forum, the general conclusion for this seems to be a ripped cv boot but I have checked mine and they are 100% ok. I have replaced my rear motor mount with a hasport one. I understand an alignment would play a role but this is only while accelerating and wouldn't explain the clunk. Could it be LCA ball joints? Transmission mount also sounds possible but I dont see how that would start after lowering. Thank you very much for any suggestions!
Jason Baker
Jason
Lake George, NY
2018 Civic Si Coupe
Have you checked the jack shaft bolts? The bolts that hold it to the motor?
Can you tell if it is more to the Right side of Left side of the vehicle?
Maybe try putting the OEM RMM back in and see what it does?
Honda Civic 10th gen Violent shaking and clank when letting on/off gas -- not cv axle? 1670351891843
Honda Civic 10th gen Violent shaking and clank when letting on/off gas -- not cv axle? 1670351761634
Doc_Mello
2019 CBP Si Coupe
I think you circled the incorrect part, mate. šŸ˜…
OP: with what did you lower the vehicle?
Jason Baker
Jason
Lake George, NY
2018 Civic Si Coupe
No I was serious with that yellow circle. If the shaking ONLY occurs when in gear and on/off the gas, the issue may be in the drive-line somewhere. The only reason I would rule this out is because they still spin regardless of transmission status. The bolts that hold this bearing assembly are very short and prone to back out. If 2 loosened, or even 1, it could cause serious vibration.
This little fella right here. A half shaft. (not an axle)
Honda 44500-TBF-A00
Shaft Assembly, Half
2017-2020 Honda 44500TBFA00
Honda Civic 10th gen Violent shaking and clank when letting on/off gas -- not cv axle? 1670357706910
OR...... could it be the
Honda 44310-TBF-A01
Joint Complete, Inboar
2017-2020 Honda Civic 44310TBFA01
Honda Civic 10th gen Violent shaking and clank when letting on/off gas -- not cv axle? 387da31d5a6f23097ee7357907bb26fa
Let's start with the part that was changed most recently though and go from there??
Jason Baker
Jason
Lake George, NY
2018 Civic Si Coupe
Also curious..... the Hasport RMM has some really bad NVH. When you say "violent shaking", could you possibly be feeling the RMM doing it's job?
Romeoridgee
Honda Dealer Tech.
Rob
Maryland
19 SPT 17 EX-T 08 LX 21 CRV 12 Acc 14 328I CONV
get lower ball joint spacers also known as roll center adjuster, when lowering your car the angle of your lower control arm is more flat. ball joint spacer will lower the mounting point of arm to joint bringing back the correct angle needed. alignment is also needed because toe changes when lowering.
Doc_Mello
2019 CBP Si Coupe
Honda 44500-TBF-A00
Honda 44310-TBF-A01
OH! I was confused by the wording.
Good clarification, TY, and good knowledge!
snapshot
snapshot
This was happening before the motor mount and I installed it to try and fix it. It literally feels like the front of my car is going to fall apart.
Jason Baker
Jason
Lake George, NY
2018 Civic Si Coupe
Damn. Ok so it was suggested that you may need an alignment or to look at your suspension geometry.
Any chance you could record video of this?
LBP
Double-check everything you touched when installing your lowering springs or coilovers. Sounds as though this occurs during changes in suspension load. Could be as simple as having forgotten to tighten a control arm bolt.
PHubb
Paul
Rhode Island USA
2017 Civic LX, 2012 Accord
Just spit balling here - Is your car CVT or M6 transmission? We used to have a similar sounding problem on the rear drive, front engine Porches (928, 944, etc.) It was the rubber bushings in the clutch pressure plate coming apart. Reuired replacing clutch assembly.
tacthecat
Cheshire, MA
'12 Civic Si Sedan
Is there a chance you lowered the car too much and the drive-shaft flex joints are binding?
