EPSi2FKR
- Sep 7, 2020
- 29
- 171
- 272
- Dallas, TX
- 2020 CBP Civic Type R, 2014 Lexus IS350
Hey y’all,
Thanks for your time. So, the brakes seem to be giving me a problem. Two events ago, I had some brake shutter so bad, it felt like wheel hop. I felt it mostly on hard braking and some on turn in. I tried to power through it like it was a bedding/surfacing thing but no dice. Tripped a bunch of sensors and scrapped the session.
So, got all new pads and rotor rings. Went out again. It was better but still had some issues. The video is from this event. This time, the shuttering and pulsing are more at turn in. All the buzzing you hear (sounds like diving on rumble strips) and the shaking with it is the problem. It’s unbalancing the car. There was a little on hard braking (0:33) but that seemed to sort out. Most of the symptoms are on lap 2-3 of a cold 25 minute session. And once the car warmed up and at speed you can barely notice it (1:00). But by the end of that session of really getting on it, I had brake fade! I stopped the event there. Did a bleed after and fluid was indeed brown.
Some extra info. Both these events were cold. Im stilling getting better with braking but far from good. I’m going through pads in 2-4 track days, which seems excessive. This car is generally hard on brakes but not this much. It’s a weird issue. The car is at the performance shop now and They said the hubs and axels are fine. Just seeing if y’all have any ideas.
