I'm gonna guess strut bar and TIP?Haven't done much lately due to covid outbreak....but received these packages today.
me too, but before that going to do the clutch and waiting for 27won maf housing. Then I will do a tune and see what it looks like.Looks great. Looking forward to your tune results
haha, mines still unfinished so eagerly waiting for clutch to go in, finalize suspension work and couple other minor things..........before i can fully enjoy it.10/10ths build, leaves mine feeling unfinished LOL
The Si comes with a 18mm rsb, the Type R bar is 20mm and the whiteline that I have is 22mm. When I switched out to the 20mm rsb i immediately noticed a change in the way the car corners, definitely felt tighter. Over time I started getting used to it so figured lets upgrade. So went with the 22mm, and of course that made it even tighter and i loved it personally.Enjoy following your built progress very much.
Since you have used both the Type R and Whiteline RSB, I would like to hear your opinion regarding the two.
TIA
Your detailed explanation helped a lot, thank you!The Si comes with a 18mm rsb, the Type R bar is 20mm and the whiteline that I have is 22mm. When I switched out to the 20mm rsb i immediately noticed a change in the way the car corners, definitely felt tighter. Over time I started getting used to it so figured lets upgrade. So went with the 22mm, and of course that made it even tighter and i loved it personally.
If you plan on upgrading the rsb you should do it in stages from your username it makes me think you have a hatch which has a 16mm rsb. So either an Si (18mm) or Type R (20mm) bar would be a great upgrade for you to begin with, if the rsb is way too stiff for your style of driving you can spin out the back end going around a corner, you would want a little flex.
You can find Si or Type R bars everywhere for cheap as they upgrade to thicker ones. With the Type R bar you will need the type r brackets as well. I think the Si bar you can get away with your existing brackets if not you will need those brackets as well.
In my opinion for a Daily a Type R bar is more than enough. Hope this helps.
