loxias1821
- ALEXANDROS
- Apr 23, 2022
- 2
- 35
- 17
- Illinois
- CTR 2021
- #61
265/35 looks fine stock suspension.
For hub rings : 72.6/72.5mm-64.1mmThis is an awesome thread for me tbh. I just orfered T6R in black. Gonna go with some dark chrome lug nuts.
Also ordered yoko tires at 255/40R18 because it's a closer to OEM size in diameter.
Will report if there is any rubbing when i get them installed. Question: do these wheels need hub centric rings?
Very nice! What lugs are those? What happened with Fitment Ind exactly?Finally. Fitment-Industries gave me hard time. I don’t think that I am gonna buy again from there.
1320 performance M14X1.50.Very nice! What lugs are those? What happened with Fitment Ind exactly?
Which rims did you go with ?Just dropped off my wheels to get the 275/35’s mounted. Not sure when I’ll have time to switch wheels though.
Mita Y. Ordered in Jan and received about 90 days later. Was waiting on Costco to restock 265/35 ps as4 but that was taking a while so went one size wider.Which rims did you go with ?
Same here, no luck with Costco. Finally I got the PS2 it’s a nice tire.Mita Y. Ordered in Jan and received about 90 days later. Was waiting on Costco to restock 265/35 ps as4 but that was taking a while so went one size wider.
hey yeah I do see that the general concensus here is with 265/35. but I'm not tracking the car, and using it as a daily in city I don't get to much spirited drive anyway. cops here in summer are always on the lookout for cars like our civic.If you read carefully all the the thread, you gonna realize that is better to go 265/35/18. Yes you need hub rings.
Damn that seems pretty heavy for the wheel and tire combo no? I believe 49 lb is the same as OEMJust picked up the set from Costco. They look good. Total weight with Mita Y and 275/35/18 95Y ZP Michelin pilot sport all season 4 is 49 lbs per wheel and tire. Will install them in a few days, doubt I’ll get it done today.
Sorry to share this thread but I feel like it has some momentum going.
Also I just realized ZP stands for zero pressure so I bought run flats without knowing.
It’s heavier than I’d like I suppose but I’m sure it’s due to me ordering the ZP or run flat model. The wheel alone is about 18.5 lbs on my scale. Oh well they are all seasons for normal use for me. Just trying to note things as I come across them.Damn that seems pretty heavy for the wheel and tire combo no? I believe 49 lb is the same as OEM
Appreciate that correction!OEM is 53lbs
