2020 brake squeal
Tommyfk8
Tommy
Jersey
2020 honda civic type r
So I was driving home and after coming to a complete stop i noticed really bad brake squeal on my 20 ctr is this normal during the break in period? Currently car has 150 miles on it.
tinyman392
Marcus
Illinois
'18 Civic Type R (RR)
This is normal in general. If you want to reduce brake squeal you’ll need to put some heat through the pads. Normally if I put about at least 200 PSI through the brake lines the issue goes away almost completely (with some exceptions); this is in the 2018 though, the 2020 does use a different compound. The other option to rid of brake squeal is to get a new, less aggressive (not as efficient) pad. If you track the car, this may not be a viable solution for you.
fk8dc5s
Alex
OC
2019 FK8 2003 DC5S 1994 CD5
i replaced my pads with Project Mu HC+ pads and my friend those squeal. haha. stocks barely did in comparison. but it is normal for both
martindtjr
Martin
San Diego
www.flickr.com
TYPE R 19, Sienna XLE15, Xa 06, Camry 92
Normal... Wait for it to fade away after 600 miles.
As for rocks, you'll know......... it's really loud.
Tommyfk8
Tommyfk8
Tommy
Jersey
Yea i will be removing the wheel this weekend i can hear the rocks rubbing for sure thanks.
Mugenteg
Steve
NJ
Civic Type R
I have a 2019 and after 5k miles, my front right still squeals every once in a while.
MediaMaster
Mark
Frozen Tundra
2020 CTR, 2024 Ford Maverick
Just got to the end of 600 break-in on my 2020. Absolutely no squeal. Don't know if I don't use the brakes much (lol) or just lucky. Finding the CTR to be as much fun as everyone has described and I've only been to 5-6k rpm so far. We'll change that tomorrow.:cool:
Tommyfk8
Tommyfk8
Tommy
Jersey
Nice i had a pebbles wedged in between my rotor and dust shield it was horrible but its all good now as..
Tev42
Tyler
San Diego
2019 CTR
Looking at using these for daily/occasional track (maybe 3 or 4 times a year)
Have you been on a track with those pads?
speedvagen
Ohhhh!
sgp fk8 #r-26236
Lol, 2019 with 12k miles on it and under the right conditions, mine will squeal like new for long periods of time.....mostly when trying to lightly brake at a stop....once stronger pressure is applied it goes away. But the moment I try to keep from snapping my passengers’ necks at a stop (I.e., take it easy), there it is again.....
’vagen
Teach-R
New York
2019 Rallye Red CTR #22518; 2017 Golf R
2019 with 7k miles. Mine squeal frequently at slow stops. Right now I have a rock in the passenger front brake and when I’m in reverse it sounds like I’m dragging my exhaust. It’s so bad. Have to Jack the car up again and pry it out (have had to do that 5-6 times since buying the car new last March)
Patriots1959
Jason
Easthampton, MA
2019 Civic Type R
’vagen
So what I did for this is tap a long screwdriver on the break shield. Go around the circle several times. Use both ends to tap. What (I think) this does is either set the break shield in the "correct" or non-noisy position or releases the stuck rock. Tap hard enough so it does not bend the shield. If it keeps happening stop somewhere safe and do it again. Perhaps tap harder.
Good luck and please don't sue me if something goes wrong :) 99% of the time the issue will be with your passenger side front wheel.
