Touring Tweeter Upgrade
Royalz_2o9
2017 Touring Sedan
Anyone have any pics or install guide on how to splice the wires?
Never done this before so I don't want to mess up.
Heres a basic how to, i recommend soldiering the wires like one of the diagrams below, if you scroll up on this thread there should be a diagram showing the colors to speakers and polarity so you have an idea.
https://www.wikihow.com/Splice-Wire
LegendaryElite
Tallahassee, FL
2017 Civic EX w/ Sensing
Check my post on page 7 to see how to remove the stock tweeter.
The color code should be pink-positive, grey-negative.
I recommend welding the wires together to avoid any connection issue, but if you're not experienced in electronic work just use butt splice.
xjoshuax89
Josh
Maryland
Mine was Green and Yellow. I watched a few videos. Doesn't look super clean but it works and sounds better than stock tweeter so I guess it worked.
I was curious about where to cut off the oem connector and then how to connect the wire to the connector and which one to use. Just watched a couple YT clips and guessed. Took a few tries of hit and miss but I got it to work.
Fountainhead
ray
Orlando FL
2019 Honda Civic Type R
Just a note about determining polarity on tweeters:
First, note the wiring on the factory tweeter.
Then, remove the factory tweeter from factory harness, and take a small battery 1.5v and touch each end of the tweeter terminals with a wire then touch across the factory tweeter.
When the tweeter cone moves out, then that tells you the polarity of the tweeter terminals. (May need flashlight to see cone movement).
Then note which terminal that the (+) of the battery was connected to when the tweeter moved out.
That terminal is your (+) lead on the wire harness.
NickoJDS
AlohaFK7
Nick
1988 Honda ED3/EF2 Sedan, 2010 Honda FG1 Coupe, 2019 FK7 EX
I made some measurements for my own future reference when I decide to buy some better tweeters that should help you decide if what you want will fit. Here they are (click for larger):
IMG_20160918_1918480.png IMG_20160918_1919115.png IMG_20160918_1919401.png IMG_20160918_1920161.png IMG_20160918_1920567.png
Can you help me read this? I’m not too familiar with reading a caliper /:
xenon04
Czech Republic
Civic Sedan 1.5 MT
(millimeters - inches) 43mm - 1,7in / 28mm - 1,1in / 38mm - 1,5in / 58mm - 2,3in / 49mm - 1,9in
I bought a Hertz CK 165 with C 26 tweeters (their dimensions)
I'll try to connect without the crossovers (have a "premium" audio)
Honda Civic 10th gen Touring Tweeter Upgrade IMG_3015-Edit
ddood
Australia
Honda Civic 2016 VTI-LX
What a coincidence, I just installed these last week! The plastic housing needs to sanded down a tad to get these to fit otherwise was a breeze to install, especially with the supplied metal bracket and screw.
Honda Civic 10th gen Touring Tweeter Upgrade IMG_20190902_090356
xenon04
Czech Republic
Civic Sedan 1.5 MT
when I see it, maybe I remove that chrome ring
Honda Civic 10th gen Touring Tweeter Upgrade IMG_30231
Civicsi19
2019 Civic SI Sedan
Hertz is the way to go. I have HERTZ tweeters and door speakers. I also added hertz to the rear deck. Super nice improvement over my stock SI speakers. Your not going to get a bunch more bass out of the speakers but your gonna get incredible clarity from them. Music sounds so much better. I used HERTZ MPK 165.3 Mille pro in the front and rear. It's not cheap but its worth it in the end. Especially if your going to add an amplifier. I've used HERTZ in all my cars. Not once have I ever had an issue with them. Best speaker company in my book. I will never change brands, and trust me I've pretty much tried them all
Mikex18
Michel
Montreal
2017 Civic Sport Touring
So i ordered a set of JBL GTO19T, the wires thst come with then have a crossover in them.
I have a touring, do i cut the crossover and re-install?
hicompb18c1
San Diego
2019 Civic Si Sedan, 2018 Accord LX (wife's)
Which speaker/tweeter combo are you running in your front doors? Also in a 19 Si and need to get rid of my tweeters ASAP... my music actually sounds better if I cover the tweeter up with my hand LOL
2016TouringSLC
2016TouringSLC
Salt Lake City
2016 Honda Civic Touring
The short answer is "yes, cut out the crossover." The tweeter speaker wire in the Civic is already run through a crossover in the stock amplifier, so if you leave in the second crossover, it will be a crossover on a crossover, and it will not sound good.
Cut off the tweeter crossover and attach just the tweeter speaker wires directly to the speaker wires from the Civic amp, and you're good to go.
Mikex18
Michel
Montreal
Thanks Man
Honda Hopeful
Chicago, IL
2018 Honda Civic Si
I would do a little more investigation regarding the crossover. My understanding from other threads is that the stock tweeter mount includes an integrated capacitor (see yellow cylinder in below image, copied from another post) that acts as a bandpass filter to provide a rudimentary crossover. If true, then the stock amplifier is not solely splitting the frequencies between woofer and tweeter. Which is to say, I personally left in the inline crossovers that my aftermarket tweeters came with.
Honda Civic 10th gen Touring Tweeter Upgrade upload_2019-9-30_21-22-0
