Might also be sourcing or pricing related consideration. Only Honda knows. ?And the worldwide confusion from Honda continues.
Maybe they build engines "potluck" style.
AFAIK the "stronger" rods applies to those engines with higher power/boost output such as the Si/CRV/Accord.Well, with CAPTS saying that their sedans have the weaker rods and Arnoldo from Asia saying their L15B7 based hatches have the thinner rods as well, I wonder...
Years ago Derek said only the Si's had the better rods. Then Eman said the hatches have the weaker rods and all others use the same rods as the Si. I wish Eman was a member here and could comment or even if we could hear from Derek again. Things actually seem very unclear at this point.
Or is their really no definitive answer and the rod used varies from engine plant to engine plant?
The only thing is that in the US, "Eman" is well known (and legit) and has torn apart many 10th gen engines and says the non-Si sedans and coupes use the Si rods as well. And that all hatchbacks have the weaker, thinner rods.AFAIK the "stronger" rods applies to those engines with higher power/boost output such as the Si/CRV/Accord.
1 of the main reason that i can think of is likely due to different regions with different specs or requirements.The only thing is that in the US, "Eman" is well known (and legit) and has torn apart many 10th gen engines and says the non-Si sedans and coupes use the Si rods as well. And that all hatchbacks have the weaker, thinner rods.
I only started this thread today because I saw a few sites online that said the L15BA motor had the weaker rods, but that that particular engine was only in the Sport and Sport Touring hatches. As it turned out, all the hatches in North America are L15BA. That was my bad and I apologized for posting incorrect info.
But now with you saying the sedans have the weaker rods and Arnoldo saying the L15B7 in his hatch definitely had the weaker rods, I'm thoroughly confused.
Maybe that's it. Eman is US based and I'm sure his info is accurate for the Swindon built hatches and North American coupes and sedans. With you and Arnoldo being in a different region of the world, I guess certain specs and some components are different.1 of the main reason that i can think of is likely due to different regions with different specs or requirements.
Can you check this information without tearing down the engine?I can confirm L15B7 hatchback in Asia uses the weaker rod.
I was thinking about this too. Pulling a spark plug and using a boroscope to see what's embossed on the top of the piston would be one way. I'm considering doing that the next time I'm waiting for my oil to drainCan you check this information without tearing down the engine?
Wouldn't the piston be different between models?I was thinking about this too. Pulling a spark plug and using a boroscope to see what's embossed on the top of the piston would be one way. I'm considering doing that the next time I'm waiting for my oil to drain
the "better" piston comes with the "better" rods & yes it should be 1 of the easiest way to chk the rods.Wouldn't the piston be different between models?
Better to check true the oil pan and look for the 5PA casting mark on the big end of the Rod.
