Fatherpain’s 2018 Type R
KYRGYZ
Bay Area
16 Civic LX, 18 Model X 100D
if this is not the most detailed and organized build thread I've ever seen I don't know what is... bravo! lots of useful info!
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 0C1E591B-A029-4528-B883-3BD495E82064
Huge thank you to Cory and C&R Racing for
getting a revised C&R/HKS replacement core in time for my next track day, just as they said. :headbang:
Won’t post a full install, as it’s the reverse of the removal which can be found here. If needed just scroll back.
Instead, will share what was done to overcome some unexpected roadblocks, which made what should have been a (1) hour re-install into a (5) hour trial and error problem solving session. :bonk:.
But my inner OCD weirdo, jones for these situations... Especially when able to successfully figure it out. Modding is a hobby after all :cool:
Please know this is not a criticism of C&R Racing. Their customer service has been stellar and this upgrade isn’t a mass produced item. Imagine it’s more of a fan service for a handful of hardcore Type R track drivers, so I am grateful this is even available. :bow:
Have found it’s not uncommon to need to make adjustments to get performance parts to fit the OEM locations. The C&R Racing HKS oil cooler replacement core was no different.
Honda Civic 10th gen Fatherpain’s 2018 Type R 4C3A857F-FE85-4CCE-ACD2-C53EB35B2BB2
To refresh, the first issue encountered were the end brackets where too wide and wouldn’t fit the HKS hardware, so C&R had me send it back.
Honda Civic 10th gen Fatherpain’s 2018 Type R DA262B23-B2E0-4D5B-9399-B0782EF3F147
(1) week later, received a revised core, with brackets resized.
Honda Civic 10th gen Fatherpain’s 2018 Type R 417035F4-1329-41DB-9F7A-1150D8BC70BA
Yes yes yes!! Core now fits the channel perfectly. :thumbsup:
Honda Civic 10th gen Fatherpain’s 2018 Type R 3EAC0EE2-27C2-4440-8D38-AABA9D85E1D7
Thought it would be easy work after that... but ran into some weird fitment issues affecting these (3) connection points.
If any (2) lined up, the 3rd would be off. :banghead:
Honda Civic 10th gen Fatherpain’s 2018 Type R 0CA90A9C-15A6-4E04-8A95-6D7B775B4E6B
Didn’t initially realize there was still a fitment issue and the first attempt resulted in the nutsert/rivnut cross threading. :doh:
Ran to Home Depot for a M6 tap and was able to save the threads. :headbang:
Honda Civic 10th gen Fatherpain’s 2018 Type R 07F5942B-3688-4456-9639-361AA8E8050C
Once it became apparent something was off, began the tedious process of uninstalling and reinstalling the core, bolts and all, to see where the hang up was.:what:
Honda Civic 10th gen Fatherpain’s 2018 Type R 8F31A19A-E734-493E-967A-1820765BF372
Unsure why this top bracket was so out of whack...This was the closest I could get it to line up. ?
Didn’t have the luxury of time, to compare it with the original HKS core... Was in “GIT ER DONE MODE!” :flame:
Briefly considered cutting the vertical tab and asking a buddy to weld it back in the right location...Oh gawd.
Honda Civic 10th gen Fatherpain’s 2018 Type R 9A2A32C6-E370-4F55-8C95-7B275BC4C649
Instead, went with the “KISS” mantra... Keep it simple stupid! Pulled off the silver bracket instead, switched to longer M6x30mm bolts and added (6) washers to the bottom and (5) to the top to act as spacers.
Honda Civic 10th gen Fatherpain’s 2018 Type R B3005A7B-266C-4674-A3F8-138DA16BBE5B
With the bracket pushed outwards, the tab now lined up. Brilliant! :yes:
Honda Civic 10th gen Fatherpain’s 2018 Type R 554A60CC-E743-401C-9708-DA4BD5CD9437
Was a little tricky to get these connections started... but patience and finesse paid off. Don’t forget there is a spacer washer on the backside of the lowest bolt that is circled.
The (2) bottom arrows are pointing to the rear bracket. Tried to fit the last (2) bolts but it wouldn’t go...
Honda Civic 10th gen Fatherpain’s 2018 Type R 9BC5F52F-6AE8-464E-BFF5-F0AAE7825FA1
Crawled under and looked up. A-ha! You rat bastard!
Honda Civic 10th gen Fatherpain’s 2018 Type R 8677E5C3-8AC2-4788-94E0-8A5A3E22ACDE
For some odd reason, the backside of the core brackets and the HKS hardware had a little bit of mismatch. Reached up and marked it with a sharpie.
Honda Civic 10th gen Fatherpain’s 2018 Type R 73CB107F-FBD4-42B3-80FB-14A02C4B9DE5
This is the amount on the core that needed to be trimmed. Much easier to adjust soft aluminum on the C&R than SST on the HKS. Smarter not harder ;)
Honda Civic 10th gen Fatherpain’s 2018 Type R 054FCE01-1D58-4441-A9AD-8B2A17B06AA9
A coarse round hand file worked well to enlarge the holes.
Honda Civic 10th gen Fatherpain’s 2018 Type R A2B847B7-934C-474F-B960-0B920B0B9396
Here is that backside C&R core bracket adjustment that did the trick.
Honda Civic 10th gen Fatherpain’s 2018 Type R 66ED0E93-33DB-455E-B899-8877EDD41BCF
Heyyy now, brown cow!! Everything all lined up and secured! Don't forget the aluminum conical seals for each AN-10 fitting :p
Honda Civic 10th gen Fatherpain’s 2018 Type R CC82700D-B49A-41C6-879E-C9544AAC546B
Wrapped up just past midnight. A big relief it’s in. More so, since I’m working all day Saturday... Leaving just enough time to refill the oil, slap the front bumper on, torque the last wheel, wash, then test drive the car and pack my gear for Big Willow Sunday.
Weather forecast for Rosamond is 85F and Big Willow is a high speed track so don’t anticipate any heat issues, whatsoever.
The ultimate test will be on a hot day when the car is finally tuned. Confident this core will provide the extra margin needed.
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 4E387261-58E9-4471-992B-10B5FC861BB1
Had a fun track day again at Big Willow. Alfa Romeo Club of Southern California put on a nice event, which included some classroom time. Even though it was my 3rd time on this track, still a novice of sorts and the instructor shared all kinds of wisdom how to attack the course and maintain speed:
  • Don’t worry about lap times
  • Focus on driving smooth
  • Focus on shifting smooth
  • Focus on braking smooth
  • Everything smooth!!
  • And here are the lines and apex’s to take.
Me: Sir yes sir!!! Got it boss!! :bow:
Honda Civic 10th gen Fatherpain’s 2018 Type R 1C4E58F3-8B21-4E64-935E-4E38E8C7FA0D
Endowed with this track wisdom, proceeded to confidently go out... and have a couple scary, “Whoa, sure did that wrong” moments. Fortunately the RE71R tires grip never failed and I didn’t go off.
This of course, reminded me of “Iron” MIke Tyson’s famous quote above. :rolleyes:
Honda Civic 10th gen Fatherpain’s 2018 Type R 49E4B0D3-4480-4FFA-BC49-A25AF19961A5
Fortunately, was able to settle in for the 2nd session and posted a personal best 1:38 in the intermediate/novice group. Passed lots of cars, so moved to the advanced group.
Thought I drove smoother and faster there for the 3rd session @1pm... but was surprised and a little disappointed my lap times dropped to the 1:41-1:42 range... though the RE71R’s began to feel greasy. :dunno:
Honda Civic 10th gen Fatherpain’s 2018 Type R 6791B50E-C149-4CE6-9E7B-39E96648199E
This was the condition of the RE71R’s at the beginning of the day.
Honda Civic 10th gen Fatherpain’s 2018 Type R F78236E4-D2E4-4F00-A584-20F3715120F4
Same tire after (3) 15 lap sessions. Having driven them to the cords, my day was done, with (1) session remaining. :confused:
Will need to purchase a new set of tires and will try Yokohama A052’s next. Have heard they offer better track grip and last a bit longer.
Each session lasted (30) minutes. Good for (15) straight laps of hard fun driving, so didn’t come away disappointed. Was able to complete all (3) sessions with no issues.
Temperature gauge never moved off the normal reading and didn’t run the heater. Ambient temps reached a high of 83F and the Big Willow is a really fast track.
Believe the recent cooling mods are an improvement and looking to coming back Oct 31st to drive Streets of Willow :thumbsup:
fatherpain
fatherpain
Tom
Thank you RBrackett. My first (2) track days were at Big Willow and didn’t think much about it at first. Was interesting returning after a couple outings on the lower speed, turn heavy, canyon carving-like Streets of Willow.
The higher speed at Big Willow adds a significant element of APF (A-hole pucker factor), especially on turns 1, 3 and 9 (for me at least). :rolleyes:
Approached turn (1) at around 130mph then braked late and dropped speed down to 80-90mph.
Went into turn (3) around 105mph then dropped to 65mph and experienced understeer where had to let off the accelerator to let the traction catch up. Not sure I’m doing that portion of the track correctly.
Turn (9) is tricky, because the track goes from a smooth curve on (8) at about 115-120mph to a shaper turn on (9) at about 90
mph. Felt I took this fairly well all day.
Current brake setup is Girodisc front and OEM rear rotors. Girodisc SS street pads for the front and Gyrodisc Magic for the rear. Brake fluid is Motul RBF-660.
Was braking hardest on the 3rd and last session. Afterwards, noticed the driver’s side front rim had some rubber smoke rising, but couldn’t pinpoint where it was coming from. Tire was shredded pretty well. Will know to bring the car in s There was some slight indication of brake fluid leaking from the bleeder valve, but it had cooked off.
All in all, the brakes are confidence inspiring. Held speed longer than normal and the brakes did their job well. It’s scary heading into a sharp turn at 130mph hoping the brakes will slow you down enough not to understeer and fly straight off the track. :oops:
Anticipate fresh brake pads will be needed soon.
May consider Gyrodisc track pads at some point for increased stopping power, though they are noisier and will wear the rotors down quicker.
Glad you had a fun and safe track day!
How'd the brakes hold up?
fatherpain
fatherpain
Tom
Kefi yes. Moving at a turtle’s pace, but will attempt the Motec ECU install this week, time permitting.
Honda Civic 10th gen Fatherpain’s 2018 Type R 942EA93D-F252-421D-9353-0F919A2FA512
Honda Civic 10th gen Fatherpain’s 2018 Type R 05B95363-DEF5-441E-9BE0-AB5A639BC91C
The FK8 AU kit comes with detailed step by step instructions, so should be pretty straight forward.
Reached out to Ben @Salasko Racing today. Verified I had everything needed and he confirmed availability to link this weekend to review and tweak the canned Motec tune. Once that’s done, will look into renting a dyno for Ben to remote tune the car.
@turbociv910 recommended Salasko Racing for the remote tune and it’s been great so far. Ben specializes in Motec and does not tune Hondata or Ktuner. He has been very responsive and patient answerIng questions whether email or over the phone.:thumbsup:
Of course, this time table is dependent on the HKS BOV and Motec being on the car, and new tires for when the car is on rollers.
Goal is to have this done by the next track day Oct 31st @Willow Springs
what was this I heard about a motec? :headbang:
NapalmEnema
Alex
2017 M2, 2022 Audi RS3, ex2019, now 2021Type R!
With a track day approaching, it was time to remove the center caps and switch back to hub centric rings... Also needed to bleed the brakes... Til now, have been doing the (2) person method, where someone needs to press the brake pedal while the other guy bleeds and refills the brake reservoir... What a pain.
Have been looking for a good option to accomplish this task alone... Enter the “Speedi-Bleed“ pressure brake bleeder kit :bow:
Comes fully assembled with a brake system C900 adapter cap, fill bottle, regulator, an air fill line, tubing in between and a plastic storage box.
https://www.speedibleed.com/
The link has a nice video demonstrating it in use... And convinced me to give it a try.
The cap adapter twists on in place of the OEM brake fill cap. Really like that it clears the J’s Racing strut bar with no issues. :headbang:
Removed the cap from the fill bottle, which dropped in perfectly beside the ECU.
Poured in (1) bottle of brake fluid.
Then twisted the cap back on tightly. The fill bottle has a minimum level marked that needs to be maintained. (1) bottle of brake fluid put it well above that.
Removed a cap from (1) of the tires to provide air pressure to power the Speedi-bleed.
Connected this end of the Speedi-bleed to the tire, per instructions.
set the regulator to 10-15 psi per the instructions.
Removed the rubber bleeder caps and connected an old water bottle with clear tubing through the cap. Bled each brake in this sequence:
Driver side rear
Passenger side rear
Driver side front outer then inner
Passenger side front outer then inner
Tools needed:
10mm and 11mm flare nut wrenches
10mm combo wrench
Paper towels for any spills
The Speedi-bleed maintained a uninterrupted supply of brake fluid throughout the bleeding process. Made sure to check the fill bottle towards the end to make sure it was still above the minimum.
Bled all (4) brakes in a matter of minutes. The tire supplying the air pressure dropped maybe 1 PSI.
Disconnected the Speedi-bleed and returned everything back to normal.
Wow. Very impressed with this brilliant tool. The Speedi-bleed is a game changer, how easy it makes brake bleeding, which until now, I didn’t like doing.
As an added bonus, It stores nicely in the provided case, ready for next time. It will also bleed the clutch. Highly recommended :cool:
How much air did you lose in the tire with the process? Really neat man! I've never bled my brakes on any car and have dreaded trying it.
fatherpain
fatherpain
Tom
Hey there Napalm,
I’d say about 1 psi is lost from the tire that supplies the Speedibleed with pressure. Can also use a spare tire ;)
The Speedibleed makes the process super easy, highly recommend it. :)
fatherpain
fatherpain
Tom
KYRGYZ, thank you, really appreciate the positive feedback. Welcome, glad you found us.
It’s been about (1) year since this build thread began. Didn’t know much about modding or working on cars at the start.
However the Type R has become a hobby...as has writing and sharing about what’s been encountered along the way..
OCD kicked in after a post or two, and here we are (38) pages later ?
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 989ED7BE-08FC-4093-B6E1-561F55C8A12A
The HKS BOV (blow off valve)... Probably wouldn’t be a stretch to describe this as the single most divisive mod available for the FK8/Type R platform.
There has been numerous back and forth here on CivicX and elsewhere about potential damage running this on MAF tuned cars, as opposed to safely running it on speed density with MoTeC.
The sole purpose of the HKS BOV is to make cool whoosh noises. To my knowledge there are no performance gains to be had.
Still, I’ve wanted one ever since I’ve had the car. My good buddy boosted180sx can attest to this. And while there are plenty of folks rocking these with no apparent issues, I’ve held off until now to install simultaneously with MoTeC.
This is what is included in the SSQV HKS BOV Kit.
As I am running an Eventuri intake, the parts circled in purple will not be used. They are incompatible with the airbox.
Instead they will be replaced with the Evasive Motorsports Eventuri adapter kit In blue.
Evasive Motorsports posted a really good install video:
But for some reason, the narration stops at about the 16 minute mark where I needed it most :doh:
turbociv910
taylor
wilmington nc
Cant wait to hear it!! Once i hear yours, ill be running to do the same. The stock recirc valve on the EFR turbo is pretty quiet, even with the intake.
Off Topic, but what ramps do you use?
fatherpain
fatherpain
Tom
Hey there Taylor, yes looking forward to getting the HKS BOV installed.
Started last night and am halfway through it. The next several posts will cover it along with some remedial topics like pulling the battery and airbox, needed to reach it.
The lift I’m using is the EZ Carlift. Screw jack based, made in USA. Has operated flawlessly and despite its appearance, is solid as a rock. Did a complete write up on it here if interested. :)
saint365
Chicago, IL
2017 CW Civic Type R
No Issues since installed which is about 2 years now. changed out bov sound by changing front to purple and now it make more intakes sounds then whooosh sounds.
For me even with EVS bracket, it was still rubbing with eventuri so I ended up getting whole HKS setup. Can't wait to see your installation process..where I struggled installing mine lol
fatherpain
fatherpain
Tom
Honda Civic 10th gen Fatherpain’s 2018 Type R 11956026-F2DF-42EF-95D9-04E808EC4E32
The first step of the HKS BOV installation is to remove the battery and tray underneath. Will detail that here. This post might also come in handy if need to replace the battery. Had one battery go bad and replaced under warranty.
Honda Civic 10th gen Fatherpain’s 2018 Type R 194E3523-55EF-44E4-BB20-36E6BA9A9344
First identify the terminals. Negative has a - sign. Positive has a + sign and red plastic protective cap.
Using a 10mm socket always loosen and remove the negative terminal connector first. This is because it is grounded and less chance for it to spark.
After the negative is removed, lift the red plastic cover and repeat for the positive.
Honda Civic 10th gen Fatherpain’s 2018 Type R 8377C7AD-AE40-4A23-A97C-B3E1F5CA4B99
Connectors pulled from the battery terminals. Never allow anything to touch or bridge the terminals at the same time. Cover with plastic caps if have them.
Honda Civic 10th gen Fatherpain’s 2018 Type R EDFF8508-EF0D-4C67-BD11-F646B08CEB31
This step only applies if have a strut tower bar. Remove the nuts and washers securing it. This should only be done with the car not raised off the ground.
Honda Civic 10th gen Fatherpain’s 2018 Type R D3FBC7FB-32D4-49FF-B01F-E262F1EECB92
Then lift the bar off and set aside.
Honda Civic 10th gen Fatherpain’s 2018 Type R 0BA5C958-9482-407D-9A1B-1D684D21B647
Loosen the battery retaining bracket.
Honda Civic 10th gen Fatherpain’s 2018 Type R C6DED77A-FCE6-41F2-A17D-6E2BD1DB1412
With the hooks loose, the bracket lifts right off.
Honda Civic 10th gen Fatherpain’s 2018 Type R 9D2A7578-4E47-4CA0-8AE3-9FB094733D85
Pull off the cardboard surround to get a good grip on the the battery.
Honda Civic 10th gen Fatherpain’s 2018 Type R 136BC1C4-3D17-422D-9DD5-BA2F5D219233
Battery ready to lift out.
Honda Civic 10th gen Fatherpain’s 2018 Type R 512D7AF8-F3E5-4C01-BB86-3AD80257A0EE
Battery removed. Despite it’s normal size, it is pretty heavy. Can see the benefit of switching to a lighter battery for those serious about tracking.
Honda Civic 10th gen Fatherpain’s 2018 Type R 73A10E60-E48D-4A8F-8FBB-FBA6397CF3B4
If just replacing the battery, can stop here and install in reverse order.
Honda Civic 10th gen Fatherpain’s 2018 Type R 7884941F-30C6-4CA3-B517-01CE11309FE9
For the HKS BOV install, keep going and remove this plastic tray.
Honda Civic 10th gen Fatherpain’s 2018 Type R EA204AD4-9E40-4FAB-AC0D-35EC1CF8D237
This metal support then needs to be removed. A 10mm and 12mm socket are needed.
Honda Civic 10th gen Fatherpain’s 2018 Type R 244A6193-2E02-4DC1-A407-0B63EA4C23D4
A long extension works well.
Honda Civic 10th gen Fatherpain’s 2018 Type R 676E2FF9-1EBB-4F10-9472-33727477C977
And out it comes.
Honda Civic 10th gen Fatherpain’s 2018 Type R 6A6DDEF5-5019-4F03-8745-4FAF664C6D94
Battery and under tray removed.
