ClearEyes
- Dec 23, 2020
- 18
- 73
- 13
- California
- 2017 Civic EX T
Anyone running different size front/rear tires without issues? I have a civic 2017 EXT and I had 215 45R18 Michelin PS4s all around. A few weeks ago, a large screw got lodged into my side wall on 1 rear tire and Americas Tires said it was not repairable and had to be replaced. The tech said 215 is a weird size and that I should get 225 45R18s instead so theyre easier to replace. They offered YK GTX 225 45R18s. I decided to go ahead and replace both back tires (one was unrepairable) and leave my front tires for now, as the tread is fairly worn but not the point that it needs replacing. I also got their hazard tire plan for like $20/tire where theyll replace it for free if it happens again.
I drove around for a few weeks without issues. It seems they didnt even recalibrate the TPMS or anything and the car didnt complain. Yesterday, as I was merging from a freeway to another perpendicular freeway on a semi-circular road, I noticed my car slow down slightly and when i looked at the dash the VSA was flashing. I thought it was likely due to the tires and since it went away i left it alone. Then today, I went on a fairly long drive ~ 2 hours. I switched freeways on another semi-circular road and the VSA flashed again but this time the car gave warnings for VSA system, power steering and braking system that didnt go away immediately. The car drove fine and didnt seem to have any issues, so I kept driving to my next stop. I stopped for food and started the car again - all the warning lights were still on but car, again, drove fine. About 10 mins into the drive home, the warning lights went away but on another freeway merge, I got the VSA flashing light that went away shortly. I decided to go ahead and take it into the dealership for diagnostics. 1.5 hours later, the tech tells me they got a code theyve never seen before - C10094-94 for ABS/VSA activation taking too long. He said it was either the ABS failing (unlikely) or caused by the different tires. Since the VSA always came on first and this only occurred on curved roads where VSA would be engaged, it seemed fairly obvious it was the tires. Im thinking the ABS failing would also throw other codes. Luckily, they didnt charge me anything for the diagnostics.
Now im trying to decide if I should go ahead and just replace the front tires - they probably have like 2-5k tread left. Or if I should hold off. Im wondering if recalibrating the TPMS might fix it, as the TPMS may detect the tire differential and adjust.
I know having different tires is very uncommon on FWD cars, but has anyone had different tire sizes without issue? My civic is tuned on phearable 1.5. Ive had this tune for almost 3 years so I dont think the problem is related. Im thinking I may just go down to Americas tire and bite the bullet on the $500 to replace the front two tires.
