KyangJ
- Johnny
- Apr 26, 2020
- 3
- 21
- 9
- Nc
- 2020 Honda Civic Si
What’s up everyone. I own a 2020 Si coupe and I have been having trouble with shifting into gears(I can shift when car is off and I can also shift the car when it is turned on and on jack stands. But I can’t shift when car is on ground and not turned on). This happened 1 month after installing my stage 2 competition clutch with a light flywheel. I also have an acuity fully shiftable shifter assembly. I am still running the stock clutch line, I just now ordered the prl braided clutch line. I also ordered the Sirimoto v2 CMC and a stock CSC(In-case my oem one right now isn’t good.) I flushed out my whole brake reservoir and added in new DOT 3 synthetic Prestone brake fluid(Yes, I also bled my system.) After bleeding out my csc and flushing out the system, my car was able to shift when the car was on the ground and ignition on. I drove the car for a around for a bit but after a few mins, my car wouldn’t want to shift anymore, same problem. Any suggestions as to why this problem is happening?
