My 18-year old Mazda MPV minivan was traded in this year with fully-performing, ice-cold AC which has never been serviced in any way by me or anyone else. Original compressor, condenser, refrigerant, fans. And the AC was used a lot.Is it normal for a 4 year old civic to need an AC recharge?
I think it's up to your demand. If you use it a lot, it will be normal. If you do not use it regularly, check whether there is a leak in a hose, connector or other part of the system or not.Is it normal for a 4 year old civic to need an AC recharge?
Use a lot or not it is nothing to do with a low pressure. It is a leak or need a A/C service ; remove damp in system and recharge.I think it's up to your demand. If you use it a lot, it will be normal. If you do not use it regularly, check whether there is a leak in a hose, connector or other part of the system or not.
On the contrary. The systems that are used rarely tend to loose the refrigerant quicker over time. That's because the o-rings dry out and shrink, allowing the refrigerant (gas) to get passed them ever so slowly.I think it's up to your demand. If you use it a lot, it will be normal. If you do not use it regularly, check whether there is a leak in a hose, connector or other part of the system or not.
Your single vehicle experience does not apply to every vehicle ever. That being said, AC hoses like to develop leaks at some point due to pressure, weather, temps, and natural degradation of rubber. They are not meant to last forever. Be glad you don't have a condenser leak.My 18-year old Mazda MPV minivan was traded in this year with fully-performing, ice-cold AC which has never been serviced in any way by me or anyone else. Original compressor, condenser, refrigerant, fans. And the AC was used a lot.
So no, it's not normal. It should not leak.
On the other hand, if the leak is very small, you can get by with recharging at least for some time.
It has. If the compressor is not working, the pressure in the system is lower (equal to the pressure in the can). The amount of refrigerant leaking through any hole obviously increases with pressure. The condenser is on the high pressure side.Use a lot or not it is nothing to do with a low pressure.
You missed the point. It applies to the actual question asked. One cheap car example proves that it is not rocket science to make an AC system which lasts through the entire life of a car. If Honda AC systems indeed often fail much earlier, it is not "normal", it is inferior enginering and/or manufacturing.Your single vehicle experience does not apply to every vehicle ever.
You can recharge it yourself like any other single-component refrigerant, but the problem is that it has been artificially made expensive, so frequent recharging with a significant leak might not make sense from the point of view of price and hassle.The AC system is a closed system and should never leak, if it does leak the leak needs to be repaired evacuated and recharged. A system with r1234yf refrigerant can not be “topped off” the leak must be fixed first. At least that’s the requirement, you might find a shop that will top it off, but they can loose their license to purchase r1234yf if they’re caught doing that.
I presume this is for your 2014 Civic? No. It shouldn't be "normal", but as others have mentioned, time and use contribute to condition. In an apples vs orange competition, both my 2005 VW and 2005 Toyota lasted 12+ years and 200,000+ miles without AC system issues, which is why I would say this shouldn't be "normal" nowadays.Is it normal for a 4 year old civic to need an AC recharge?
