Aftermarket Headunit and Premium Audio System
Andy
Orlando, Fl
2020 Civic Touring coupe
Did you all figure out the buzz/hiss through speakers at any volume problem? Thanks
TheLastCoupe
Angel
Chicago
2017 Honda Civic Si Coupe
Had the joying for a while now and I would say not bad. I have the manual so I had to find out which cable was the reverse cable and splice it.. but I had to splice it to their harness so I didn't touch my factory cable. The lane watch for me only worked when I turned right. The bottom didn't work idk why. And take a picture of the 2 boxes that come with joyings harness. That will help you with research if anything doesn't work. Also you will have to bypass the radios HD box thing. Idk what it's called. If you have a sedan there is a video out there. Basically it's in front of the rear passenger wheel well behind the trim inside.. also you have to wire the GPS. I put it in the same spot as the factory one. good luck hopefully everything works.
